TwinTurbo.NET: Nissan 300ZX forum - this is what I did before I purchased the plug.
itsa300zx
on March 24, 2015 at 11:17 AM
I just tapped the center hole for pipe thread
posted by xpwarrior
on March 24, 2015 at 11:02 AM
Cut off the threaded male port from the cast EGR, this is the same thread as the exh mani port. Then drill and tap 1/4" NPT plug into the cut face side. Use this two piece fitting to plug the exh EGR port hole.
I need just the bolt-plug for the EGR port in the exhaust
Zuberman
10:52:42 03/24/15
xpwarrior
11:02:27 03/24/15
this is what I did before I purchased the plug. -
itsa300zx
11:17:06 03/24/15
Can you buy just the plug by itself? (n/m)
Zuberman
11:23:31 03/24/15
yes, Bernie FTW. (n/m)
itsa300zx
12:06:30 03/24/15
I used an oil drain plug.
Goldchocobo
13:55:21 03/24/15
thanks for sharing that, never even crossed my mind. (n/m)
itsa300zx
16:35:10 03/24/15
dang. I should've thought of that....and I could take the
Zuberman
05:42:59 03/25/15
THIS is the plug you need
Goldchocobo
15:45:47 03/25/15
Found the EGR delete plug part number
Zuberman
07:21:06 03/26/15
